PC Build any - Thoughts?
Hey I really want to get into PC gaming this is my system so far i need to know if all these parts are going to work.
 Motherboard - ASRock Z77 Extreme4 Motherboard - Intel Z77 Chipset - Socket 1155
 CPU - Intel Core i5 2500K Unlocked Quad Core Processor - Socket LGA1155 - 3.3GHz
 CPU Cooler - Cooler Master Hyper 212 EVO - 120mm Cooling Fan
 RAM - G.Skill Ripjaws-X 8GB(2x 4GB) Memory Kit - 240pin DIMM - PC3-17000 - 2133MHz - CL11-11-11-30-2N - 1.5v - Unbuffered - Non-ECC (F3-17000CL11D-8GBXL)  I am not sure if this ram works for the system please tell me.
 Video card - Sapphire Radeon HD 7850 Overclock V2 Video Card - GDDR5 2GB 256-bit - 920MHz / 5000MHz Clocks - 2x DVI, 1x HDMI & 1x DisplayPort - AMD CrossFireX Ready - AMD HD3D Ready - AMD Eyefinity Ready
 PSU - Thermaltake TR2 700 Bronze 700W TR-700PCAU Power Supply - ATX / EPS - Silent 12cm Fan - Active PFC - 80 Plus Bronze
 HDD - Seagate Barracuda 7200.14 3.5" 1TB SATA 6.0Gb/s 7200RPM 64MB Hard Drive
 SSD - Kingston HyperX 3K 2.5" 120GB Solid State Drive (SSD) - SATA III (SH103S3/120G)
 Case - NZXT Tempest 410 Elite Midi Tower Case - 3x 5.25" Ext. & 8x 3.5"/2.5" Int. HDD Bays - 7x Expansion Slots - Cooling Fans - Steel & Plastic - Black (8C-T4NL2-WWB)
Please tell me if there is anything wrong with this system.
Thanks
I can make a better one but I need to know
  • your budget
  • do you plan to overclock any in the future
  • what country you live in so I know which online store to use
my budget is 1200
nah this is my first ever build
i live in Austraila
website i was on is pc case gear or mwave
Cool, I'll try to get to this tomorrow or the next day when its my day off from work
ok thanks mate :)
Here's a good one all prices are from PC Case Gear
Motherboard=ASUS P8Z77-M PRO($129)
CPU=Intel Core i5 3470($189)
GPU=Gigabyte GTX 660Ti WF2($325)
OS=W7 HP 64bit OEM($95)
CPU Cooler=CM Hyper 212 EVO($36)
SSD=Samsung 830 Series 128GB($99)
HDD=Seagate Barracuda 1TB($79)
PSU=Silverstone Strider Plus 600W($109)
Case=CM Haf 912 Combat($82)
ODD=Samsung  SH-222BB($19)
RAM=Corsair CMX8GX3M2A1600 8GB($45)
Total=$1207
Hope this helps.
