Pc Build $700
What would be the best pc for gaming at $700. Looking to run Arma 3, Skyrim, Battlefield 3 and stuff like that.
I was thinking of going intel. Like an I5 3570k or I5 3330. Amd will work too.
For the Gpu i was thinking AMD Radeon 7870 or some Nvidia card.
What would be better 8GB or 16GB of RAM?
Pretty much something that can play Arma 3 on Med-Very High. But more of High.
This is a little over budget, but it's worth it.
http://pcpartpicker.com/user/armypig/saved/1mW4
Why not the Gigabyte GA-970A-UD3  and  the FX6300 instead of the phenom ? cause he doesnt realy need a 990fx chipset board
like this
http://pcpartpicker.com/p/LwqB
im cheaper and the FX6300 is a much better cpu.vishera.
with that XT card, you can play much games on high, incombination with this vishera, a very good gaming combination
Ewww AMDs!
This is want you NEED!
Muhahahahah! MUhahhaha!!!!!
http://pcpartpicker.com/p/LwUC
the FX6300 will beat that i 5 :)
Nah, it'll be the same in gaming. Except the board that I posted supports xfire.
but yes both are very good choises the i5 is good for gaming to its just a personal choise, i would prefer the amd in this case, but the i5 is ofcourse  a good choise too, especialy if he goes for the K
 Maybe this? http://pcpartpicker.com/p/Ly4z
The i5 is good for gaming and not bad at other tasks but if you are planning on doing other things with this computer than it might be wise to go with the 6300 that and some games are now starting to take advantage of those six cores so if you dont want to have to upgrade for a while you will be able to use that cpu for quite a while.
+1 like i said  i prefer the amd fx6300 in this case ☻
