[PC Build] $600 to $800 budget
PC Build Between $600-$800
Hello! My name is Goodish and I am relatively new to "PC Building". For the past 3 years I've been using my Sony VAIO laptop to game online. Over time my laptop has been become less and less reliable. Last year my Hard-drive was fried, (Their were other smaller problems that came up when I got it repaired) But lately it seems that performance wise my laptop is sliding on a downwards slope. I've finally come to the conclusion that I would like to build my own gaming PC. Over the past week I have been spending time looking up the best products for my price range, the only problem I am coming across is the lack of experience I have. Two products look the same, have the same price, and the same specs but they are made by different companies. If anyone has a $600-$800 PC build I would love to see it! Some things to note,
  • I don't need a mouse pad or optical drive.
  • I play very few games that are graphics heavy. I don't play games such as BF4, GTA V, COD ect. on my PC. I don't plan to play these games on my PC because I own the Xbox One. ( I actually enjoy playing games on medium graphics because I find the Ultra high settings to be a bit flashy :P It's hard to see what I'm doing with all the lens flares n' such)
  • If anyone could recommend a case that could fit into the build that would be splendid! I don't care about looks, I care about performance. As long as the case can keep my PC cool I'm happy.
  • I do not plan on over-clocking this PC.
  • If it comes to it I am willing to spend up to $800, I would prefer to keep the build a lower price but I'm open to both options.
This is my current build, if you have any tips or stuffs please send me a message :P http://pcpartpicker.com/p/bnjqnQ
That is all! Thank you for reading my post <3
What sort of form factor (size) are you looking at?
What does that mean? :P Very new to all this stuff.
Quick Version:
ATX: Your classic full size desktop computer cause
MATX / ITX, Much smaller.
Yes that skips a hell of a lot of details but in a very nutty nutshell ,it's a start.
Total case size? It doesn't matter. Size isn't a problem.
http://pcpartpicker.com/p/FY9R3C
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($176.95 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($51.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($43.99 @ Newegg)
Storage: A-Data Premier SP610 128GB 2.5" Solid State Drive ($49.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($48.89 @ OutletPC)
Video Card: Sapphire Radeon R9 285 2GB Dual-X Video Card ($184.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($36.99 @ Newegg)
Total: $628.76
You won't do much better than that in that price range.
If you're willing to go further towards the $800 max you could get a nicer GPU but really not necessary given what you've said you'd be doing.
I'm looking for an ATX, I am willing to go up to $800 for this PC. Anything is better than this machine.
http://pcpartpicker.com/p/zcHnvK
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Micro Center)
Total: $643.76
The 860k won't be as fast as an i5, and may bottleneck a bit in some CPU heavy games, but with the saved money the GPU is a 390, which should be fine for just about anything up to 1440p. Also a bit of room for the cooler, and the case is just personal preference it's a joy to work in. Or you could easily fit in a 120gb SSD for the boot drive
Or you could get a less expensive case and up the CPU to an i5 with ease.
http://pcpartpicker.com/p/mrcyzy
he should really do an updated video
860k is a bit faster than the 750k
For cheap to mid (even higher) gameing there is no contest
How does this build look? http://pcpartpicker.com/p/bnjqnQ
Personally, I'd change the case to the corsair 330R not much cheaper but much nicer.
Swap out the 960 for a R9 380 depending on sale prices
Budget in for a 120gb ssd, the Samsung 850 Evos are reasonably priced and perform well.
Would you recommend the MSI R9 380 Gaming 4G or MSI R9 380 2GD5T OC? :3 I'm asssuming the 380 Gaming.
I'd bump your 960 up to this one:
Indeed. 380 4GB Gaming
If you drop your monitor to a 21.5" one they're usually around 120, you could then up your power supply to one around 750W just to get some additional headroom.
Thank you all for the helpful suggestions! This is my (close to) final build, I believe it will work pretty well. I'm going to work on buying an SSD later on along with a better graphics card. http://pcpartpicker.com/p/xCRqnQ
Make those changes and it's a rather nice build indeed.
