Pc Build ~1200$ help please
I want to build a gaming pc. the overall budget is more or less 1200$ (including some 1080p monitor), can someone suggest parts and everything? Also should be noted that i am from Lithuania in Europe, so unfortunatly my avaliable parts list is quite small :(
Plus, most of you guys are complaining that you have an old pc or something, i am using a laptop:
Intel core i3 M350 2.27GHz
4GB ram, (only 2.3GB Usable)
500GB HDD
Integrated Intel HD Graphics
Laptop is 4 yers old, has been ruined to the max. esc, a,f,x,c, keys are not working, laptop constantly overheats and turns off, speakers are not working, headset jack is broken and work only if you connect at an angle.
I do have a pc that i use from time to time, which is 8-9 years old... it has:
AMD Athlon 64 3000+ 2.01GHz
1.5GB RAM
500GB HDD
ATI Radeon 9600 Series (does not support shadder 3.0)
So my point is, dont say you pc is old
Dunno the pcpartpicker for you region :/.
Something along these lines would be good: http://uk.pcpartpicker.com/p/2gWFU
Dunno about the monitor, though.
