PC Audio recommendations (AudioN003 needs your help)
Hey guys,
i want to buy a 2.1 System for my Computersystem but i have not experience in buying audio related stuff (I found my last PC-Audio System at the trash ^^)
So i am a student and i dont have much money after my serverbuilt so it have to be cheap.
If this matters, i want to watch movies and maybe play some games and listen to music (2 Steps from Hell and Metal mostly) with this system, so i like a bit (! Not too much like in some crappy car systems) basses and i like the treble.
For good quality i have god headphones so it dont have to be the best of the best.
About the Power: I dont want to annoy everybody in my house with my bad taste of music and my last System had 10W (but only stereo. I have no idea how much power a subwoofer needs) and i was very happy with the volume so it has to be 10W or more.
I want to spend about 20-40€ and i am considering buying the MS-Tech LD-800.
Is this a good choice? Is there something with a better privce/quality value?
thank you very much for your help
Felix
That's a fairly tight budget to work with, but I have used a Cyber Acoustics 2.1 setup that was decent for the money. I believe it was like 30 USD (so it should be within your price range), and it sounded decent enough. Shouldn't be too quiet or too loud, either.
Nevermind, it's apparently over 110 euros on amazon.de
Not sure what that set you mentioned sounds like, so I'm not gonna comment on that one.
Ok Thank you anyway.
I know the budget isn't very high but i was totaly fine with the speakers i found at the trash but now they just dont fit in my room design (I dont care about that normaly but they really dont fit). And they wheren't that expensive for sure.
So i am not looking for something to really "listen" to music because i am wearing my headset all the time. I just looking for something to watch a few movies from inside my bed or with my friends and i dont want to buy the biggest shit on earth for that.
So if you guys have good experience with something like that please let me know.
