Hi all,
I’ve got a fresh Ubuntu 16.04 install with my custom 4.15.10-acs kernel (just compiled in the acs patch).
The VM is doing that thing where it doesn’t display anything on the monitor and sits there with one core pinned at 100%, almost immediately after starting the VM.
I know I’m probably missing something stupid, but I’d love a second set of eyes here.
Relevant details follow:
VM XML
<domain type='kvm' id='3'>
<name>win10</name>
<uuid>75c1ec96-8335-43a1-8199-f0e738cdca53</uuid>
<memory unit='KiB'>12582912</memory>
<currentMemory unit='KiB'>12582912</currentMemory>
<vcpu placement='static'>8</vcpu>
<iothreads>4</iothreads>
<cputune>
<vcpupin vcpu='0' cpuset='0'/>
<vcpupin vcpu='1' cpuset='1'/>
<vcpupin vcpu='2' cpuset='2'/>
<vcpupin vcpu='3' cpuset='3'/>
<vcpupin vcpu='4' cpuset='4'/>
<vcpupin vcpu='5' cpuset='5'/>
<vcpupin vcpu='6' cpuset='6'/>
<vcpupin vcpu='7' cpuset='7'/>
<iothreadpin iothread='1' cpuset='0-1'/>
<iothreadpin iothread='2' cpuset='2-3'/>
<iothreadpin iothread='3' cpuset='4-5'/>
<iothreadpin iothread='4' cpuset='6-7'/>
</cputune>
<resource>
<partition>/machine</partition>
</resource>
<os>
<type arch='x86_64' machine='pc-q35-2.10'>hvm</type>
<loader readonly='yes' type='pflash'>/usr/share/OVMF/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10-restore_VARS.fd</nvram>
<bootmenu enable='yes'/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state='on'/>
<vapic state='on'/>
<spinlocks state='on' retries='8191'/>
</hyperv>
<vmport state='off'/>
</features>
<cpu mode='host-passthrough' check='none'>
<topology sockets='1' cores='8' threads='1'/>
</cpu>
<clock offset='localtime'>
<timer name='rtc' tickpolicy='catchup'/>
<timer name='pit' tickpolicy='delay'/>
<timer name='hpet' present='no'/>
<timer name='hypervclock' present='yes'/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>restart</on_crash>
<pm>
<suspend-to-mem enabled='no'/>
<suspend-to-disk enabled='no'/>
</pm>
<devices>
<emulator>/usr/bin/kvm-spice</emulator>
<disk type='file' device='disk'>
<driver name='qemu' type='raw'/>
<source file='/var/lib/libvirt/images/win10.img'/>
<backingStore/>
<target dev='vda' bus='virtio'/>
<boot order='1'/>
<alias name='virtio-disk0'/>
<address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
</disk>
<source file='/var/lib/libvirt/images/large/win10-large.img'/>
<backingStore/>
<target dev='vdb' bus='virtio'/>
<alias name='virtio-disk1'/>
<address type='pci' domain='0x0000' bus='0x0a' slot='0x00' function='0x0'/>
</disk>
<disk type='file' device='cdrom'>
<source file='/home/kbrennan/ISO/windows-10-1709.iso'/>
<backingStore/>
<target dev='sda' bus='sata'/>
<readonly/>
<boot order='2'/>
<alias name='sata0-0-0'/>
<address type='drive' controller='0' bus='0' target='0' unit='0'/>
</disk>
<source file='/home/kbrennan/ISO/drivers-virtio-win-0.1.141.iso'/>
<backingStore/>
<target dev='sdb' bus='sata'/>
<readonly/>
<boot order='3'/>
<alias name='sata0-0-1'/>
<address type='drive' controller='0' bus='0' target='0' unit='1'/>
</disk>
<controller type='usb' index='0' model='nec-xhci'>
<alias name='usb'/>
<address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
</controller>
<controller type='sata' index='0'>
<alias name='ide'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
</controller>
<controller type='pci' index='0' model='pcie-root'>
<alias name='pcie.0'/>
</controller>
<controller type='pci' index='1' model='pcie-root-port'>
<model name='pcie-root-port'/>
<target chassis='1' port='0x8'/>
<alias name='pci.1'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0' multifunction='on'/>
</controller>
<controller type='pci' index='2' model='dmi-to-pci-bridge'>
<model name='i82801b11-bridge'/>
<alias name='pci.2'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/>
</controller>
<controller type='pci' index='3' model='pci-bridge'>
<model name='pci-bridge'/>
<target chassisNr='3'/>
<alias name='pci.3'/>
<address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
</controller>
<controller type='pci' index='4' model='pcie-root-port'>
<target chassis='4' port='0x9'/>
<alias name='pci.4'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
</controller>
<controller type='pci' index='5' model='pcie-root-port'>
<target chassis='5' port='0xa'/>
<alias name='pci.5'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
</controller>
<controller type='pci' index='6' model='pcie-root-port'>
<target chassis='6' port='0xb'/>
<alias name='pci.6'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x3'/>
</controller>
<controller type='pci' index='7' model='pcie-root-port'>
<target chassis='7' port='0xc'/>
<alias name='pci.7'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x4'/>
</controller>
<controller type='pci' index='8' model='pcie-root-port'>
<target chassis='8' port='0xd'/>
<alias name='pci.8'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x5'/>
</controller>
<controller type='pci' index='9' model='pcie-root-port'>
<target chassis='9' port='0xe'/>
<alias name='pci.9'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x6'/>
</controller>
<controller type='pci' index='10' model='pcie-root-port'>
<target chassis='10' port='0xf'/>
<alias name='pci.10'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x7'/>
</controller>
<interface type='network'>
<mac address='52:54:00:b3:70:f4'/>
<source network='default' bridge='virbr0'/>
<target dev='vnet0'/>
<model type='virtio'/>
<alias name='net0'/>
<address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
</interface>
<input type='mouse' bus='ps2'>
<alias name='input0'/>
</input>
<input type='keyboard' bus='ps2'>
<alias name='input1'/>
</input>
<sound model='ich6'>
<alias name='sound0'/>
<address type='pci' domain='0x0000' bus='0x03' slot='0x01' function='0x0'/>
</sound>
<hostdev mode='subsystem' type='pci' managed='yes'>
<driver name='vfio'/>
<source>
<address domain='0x0000' bus='0x0f' slot='0x00' function='0x0'/>
</source>
<alias name='hostdev0'/>
<address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x0f' slot='0x00' function='0x1'/>
</source>
<alias name='hostdev1'/>
<address type='pci' domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x0c' slot='0x00' function='0x0'/>
</source>
<alias name='hostdev2'/>
<address type='pci' domain='0x0000' bus='0x08' slot='0x00' function='0x0'/>
</hostdev>
<redirdev bus='usb' type='spicevmc'>
<alias name='redir0'/>
<address type='usb' bus='0' port='1'/>
</redirdev>
<alias name='redir1'/>
<address type='usb' bus='0' port='2'/>
</redirdev>
<memballoon model='virtio'>
<alias name='balloon0'/>
<address type='pci' domain='0x0000' bus='0x09' slot='0x00' function='0x0'/>
</memballoon>
</devices>
<seclabel type='dynamic' model='apparmor' relabel='yes'>
<label>libvirt-75c1ec96-8335-43a1-8199-f0e738cdca53</label>
<imagelabel>libvirt-75c1ec96-8335-43a1-8199-f0e738cdca53</imagelabel>
</seclabel>
<seclabel type='dynamic' model='dac' relabel='yes'>
<label>+64055:+132</label>
<imagelabel>+64055:+132</imagelabel>
</seclabel>
</domain>
IOMMU Groups (overridden)
IOMMU Group 0 00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 10 00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1454]
IOMMU Group 11 00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 59)
IOMMU Group 11 00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 12 00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1460]
IOMMU Group 12 00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1461]
IOMMU Group 12 00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1462]
IOMMU Group 12 00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1463]
IOMMU Group 12 00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1464]
IOMMU Group 12 00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1465]
IOMMU Group 12 00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1466]
IOMMU Group 12 00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1467]
IOMMU Group 13 03:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b9] (rev 02)
IOMMU Group 14 03:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b5] (rev 02)
IOMMU Group 15 03:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b0] (rev 02)
IOMMU Group 16 04:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 17 04:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 18 04:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 19 04:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:43b4] (rev 02)
IOMMU Group 1 00:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1453]
IOMMU Group 20 06:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02)
IOMMU Group 21 07:00.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184]
IOMMU Group 22 08:01.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184]
IOMMU Group 23 08:03.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184]
IOMMU Group 24 08:05.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184]
IOMMU Group 25 08:07.0 PCI bridge [0604]: ASMedia Technology Inc. Device [1b21:1184]
IOMMU Group 26 09:00.0 Network controller [0280]: Intel Corporation Device [8086:24fb] (rev 10)
IOMMU Group 27 0b:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 28 0c:00.0 USB controller [0c03]: Fresco Logic FL1100 USB 3.0 Host Controller [1b73:1100] (rev 10)
IOMMU Group 29 0d:00.0 Multimedia video controller [0400]: Blackmagic Design Intensity Pro 4K [bdbd:a139]
IOMMU Group 2 00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 30 0e:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [10de:1b82] (rev a1)
IOMMU Group 31 0e:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
IOMMU Group 32 0f:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480] [1002:67df] (rev e7)
IOMMU Group 33 0f:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:aaf0]
IOMMU Group 34 11:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:145a]
IOMMU Group 35 11:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Device [1022:1456]
IOMMU Group 36 11:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] USB3 Host Controller [1022:145c]
IOMMU Group 37 12:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:1455]
IOMMU Group 38 12:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 39 12:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Device [1022:1457]
IOMMU Group 3 00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 4 00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1453]
IOMMU Group 5 00:03.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1453]
IOMMU Group 6 00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 7 00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
IOMMU Group 8 00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1454]
IOMMU Group 9 00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1452]
lspci -knn
00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Device [1022:1450]
Subsystem: ASRock Incorporation Device [1849:1450]
00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Device [1022:1451]
Subsystem: Advanced Micro Devices, Inc. [AMD] Device [1022:1451]
Kernel driver in use: pcieport
Kernel modules: shpchp
Subsystem: ASRock Incorporation FCH SMBus Controller [1849:ffff]
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
Subsystem: ASRock Incorporation FCH LPC Bridge [1849:ffff]
Kernel driver in use: k10temp
Kernel modules: k10temp
Subsystem: ASMedia Technology Inc. Device [1b21:1142]
Kernel driver in use: xhci_hcd
Subsystem: ASMedia Technology Inc. Device [1b21:1062]
Kernel driver in use: ahci
Kernel modules: ahci
Subsystem: ASRock Incorporation Motherboard [1849:0612]
Subsystem: Intel Corporation Device [8086:2110]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Subsystem: ASRock Incorporation I211 Gigabit Network Connection [1849:1539]
Kernel driver in use: igb
Kernel modules: igb
Subsystem: Fresco Logic FL1100 USB 3.0 Host Controller [1b73:1100]
Kernel driver in use: vfio-pci
Subsystem: Blackmagic Design Intensity Pro 4K [bdbd:a139]
Subsystem: Micro-Star International Co., Ltd. [MSI] GP104 [1462:c303]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_390, nvidia_390_drm
Subsystem: Micro-Star International Co., Ltd. [MSI] GP104 High Definition Audio Controller [1462:c303]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
Subsystem: Micro-Star International Co., Ltd. [MSI] Ellesmere [Radeon RX 470/480/570/580] [1462:3417]
Kernel modules: amdgpu
Subsystem: Micro-Star International Co., Ltd. [MSI] Device [1462:aaf0]
Subsystem: Advanced Micro Devices, Inc. [AMD] Device [1022:145a]
Subsystem: Advanced Micro Devices, Inc. [AMD] Device [1022:1456]
Kernel modules: ccp
Subsystem: ASRock Incorporation USB3 Host Controller [1849:ffff]
Subsystem: Advanced Micro Devices, Inc. [AMD] Device [1022:1455]
Subsystem: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901]
Subsystem: ASRock Incorporation Device [1849:1220]
Kernel Commandline: BOOT_IMAGE=/@/boot/vmlinuz-4.15.10-acso root=UUID=ed857a9a-7bec-4842-916b-eb3c82e3b267 ro rootflags=subvol=@ quiet splash iommu=1 amd_iommu=on pcie_acs_override=downstream,multifunction vt.handoff=7
