Passthrough VM freezes if using GPU
Hey all,
Went to boot my VM today for some work stuff and it wasn’t booting. After putting in a vnc spice to see what was happening, I saw that it was indeed booting and working mostly as it should, just not displaying to the monitor I have plugged into the passthrough GPU. So I rebooted the VM, switched inputs on the monitor to the one going to my passthrough, and through the vnc saw it boot and hang. My CPU usage flatlined. I rebooted the VM with no monitor and everything goes fine. I can’t find anything online for this so I thought maybe some wizard here could help me.
journalctl -xe
lspci -nnk
qemu xml
vfio conf
options vfio-pci ids=10de:1b06,10de:10ef nointxmask disable_vga=1 disable_idle_d3=1
Thanks so much for any help you can give me!
I’m learning myself so I’m no wizard, but did you try using the BIOS firmware option instead of the OVMF UEFI? I was never able to get the OVMF UEFI to work right.
OVMF has worked for me for about a year, and I think BIOS is worse for passthrough VMs. Not entirely sure, but every tutorial i’ve seen (both here and on the archwiki) has said to use OVMF so there must be a good reason. If you have a working passthrough with BIOS firmware I see no reason to not give it a shot though!
