Parts Needed To Build a Console Killing $550 Gaming PC
Have You Ever Wanted to Buy a Gaming PC, But It Was Far Too Expensive? Here, you will find how to build a Gaming PC For Less Than Have the Price of an In Store Buy.
Here is what you Will Need:
Processor: AMD Athlon X4 760K 3.8GHz Quad-Core Processor ($84.73 @ Outlet PC)
Motherboard: MSI A88X-G43 ATX FM2+ Motherboard ($76.99 @ Newegg)
RAM: G.Skill Ripjaws X Series 8GB (1x 8GB)DDR3-1600 ($74.99 - $20.00 Combo with Motherboard = $54.99 @ Newegg)
RAM Addition: G.Skill Ripjaws X Series 4GB (1x4GB) DDR3-1600 (37.99 @ Newegg)
Hard Drive: Western Digital Caviar Green 1.5TB 3.5" 5400RPM (62.01 @ Amazon)
Graphics Card: EVGA GeForce GT 610 2GB (47.98 @ Newegg [$10.00 Mail and Rebate])
Case: Silverstone RL01B-W-USB  3.0 (Black) ATX Mid Tower ($34.99 @ Newegg [$10.00 Mail and Rebate])
Corsair Builder 430W 80+ Bronze Certified ATX Power Supply ($19.99 @ Micro Center [$10.00 Mail and Rebate])
Samsung SH-224DB/BEBE DVD/CD Writer ($15.98 @ OutletPC)
Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($84.99 @ NCIX US)
TP-Link TL-WN725N 802.11b/g/n USB 2.0 Wi-Fi Adapter ($8.88 @ Amazon)
BitFenix BFF-SCF-12025KK-RP 43.5 CFM 120mm Fan ($9.66 @ SuperBiiz)
BitFenix BFF-SCF-14025KK-RP 47.7 CFM 140mm Fan ($8.99 @ SuperBiiz)
Final Cost: $548.17
Not sure if this is a tutorial, or build log. If the former, just no - there are much better parts for the money, particularly where the RAM and GPU are concerned.
If the latter, congrats on the build.
To me it sounds like the OP has made a list that he/she recommends for a console killer?
If that's right, like jerm1027 said, no. That might kill a console from 2001, but we're now in a different decade now.
ehh, why?
lol what even
I think he got a bit muddled up with which console he is trying to kill, maybe he thought it was the PS2 instead of PS4.
Err nope, with that gpu you might not even be able to start a current AAA title.
For 550 bucks id probably build something like this http://pcpartpicker.com/p/3zmbP ,
though it is much more viable to use an old copy of vista or something off ebay to save  cost.
Ok, if you got 550 don't get a ssd. Dont spend 1/5th of your money on a small storage device. Sure its fast, but not worth it at all. heres a much better option: http://pcpartpicker.com/p/3zoVi
Alright, I think I fixed it. Check this out: http://pcpartpicker.com/user/GamingPCBuilder13/saved/4uHl
Fixed it, I think. Check it out for me: http://pcpartpicker.com/user/GamingPCBuilder13/saved/4uHl
Yep, that would do it.
much better.
Now that is Console killer :).. either that or 750ti instead of 260x
