Partion issues
Hello all. I have a 1TB WD Caviar Blue HDD in my newly built gaming rig. I had striped it from a old computer and on that old computer it had the C partion which was around 150GB and the D partion which was the rest. I want to make a setup exactly like this if possible. But when i go to create the partions in the windows disk managment it only allows me to bring the C Drive to 470GB which dosent make sense, im only using about 25GB on the C partion currently, why wont it allow it to go down further? Any tips?
I've always found it easier to make the partitions when installing the OS. Format the drive then create a partition the size you want it and then create the second and install the OS on the smaller one you created for it.
many partition editors don't like messing with the os partition while the os is running, you can always use a bootable editor
GParted is a good one.
