It is not possible to tell for sure, that cpu requires the revision 5 bios which was released a year and a half ago, therefore the board may already be running this bios from the factory. However even if it does require an update the system should still boot but the processor will simply be listed as not recognized in the bios. These days bios updates are very easy to perform and should not scare you.
If this does worry you this board supports the 6300 from the first bios revision.
i would say FX6300 and Asus M5A97 R2.0 mobo, this works 200% out of the box. Its a realy decent mobo, with 4+2 powerphase and digi vrm´s. only its ATX, so you need an ATX case.
I run and AMD Fx 6300 with an Asus M5a97 and it worked right out the box with no bios update required. Very solid board for the priced. Overclocked my CPU to 4.5 GHZ staple with 1,325V on the Vcore.
