So I just got my new Quickfire Storm TK Blue and I love it. But I need a mouse. I am using a G100s right now but it's so damn small.
What is a good $50 mouse for the palm grip
thanks
thanks
If you add a few more bucks, like say 20-30 bucks, you can look at the razer deathadder 2013 mouse.
Corsair M45/M65 is half decent for palm. It's designed for right handed people though, so it won't feel very comfortable if you're left handed.
Deathadder 3500dpi- 42.50
http://www.amazon.com/Razer-Deathadder-Infrared-Gaming-Mouse/dp/B002Q4U5DK
Deathadder 6400dpi- 56.99
http://www.amazon.com/Razer-DeathAdder-Ergonomic-Gaming-Mouse/dp/B00AAS888S/ref=pd_cp_e_0
Mionix Naos 3200- 49.99 (really comfortable mouse but shitty lift off distance)
http://www.newegg.com/Product/Product.aspx?Item=N82E16826580003
Zowie Gear Ec2 eVo -56.99
http://www.amazon.com/ZOWIE-Buttons-Wheel-Optical-Gaming/dp/B00H69QNKO/ref=pd_sim_pc_2?ie=UTF8&refRID=1NR200MYH3EJAPAC59TX
The death adder is extremely overrated especially when it comes to comfort. If you can save a few more bucks id check this out. It has adjustable lift off and looks really comfortable. This will most likely be my next mouse.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826580006
Also if you can't swing the $80 price tag check out the Logitech g400s. I tried it and it was extremely accurate however it wasn't large enough for my hand.
