Pairing SSD's and HDD's in RAID 5
If I bought 2 Corsair Neutron GTX (240GB) and one Seagate Barracuda (500GB), could I run all three drives in RAID 5? Also, how much faster would this setup be than having three standalone drives?
Basically, what are the benefits of RAID 5 over keeping the drives single. Thanks!
That would make the SSD's constantly having to wait for the mechanical drive to finish up whatever it's doing. I'd say get just one big SSD and store media files and backups on mechanical drives.
Ok, thank you. I like the idea of running raid, but (obviously) I'm missing some important fundamentals. Maybe I could setup up a few SSD's in RAID 0 and then have a separate HDD array for backup? I'm just throwing out ideas here, but thanks anyway.
SSD's in raid 0 you will see a performance increase.  The issue with raiding a mechanical with SSD is you put a bottleneck onto the mechanical which means your data rates will only be as fast as the mechanical drive.  Using the mechanical as backup is the better option rather than Raid 5.
Also, since you implied you are new to RAIDing, you should know that you increase failure rate of a drive by adding them together.  Its generally safe to do 1-3 without too much worry.  If you were looking at a 640GB drive and had the choice of ten 64GB drives vs. one 640 GB drive, you would be better off investing a bit more for a single drive.
Great! Thanks for the advice, I think i'll stick with simplicity and grab a larger capacity drive.
