Painting side panels
Would it be fine to paint onto the meshing on a case designed for airflow, or would the paint block it up and stop the mesh from working? The case in particular is the bitfenix phenom M I saw the nvidia edition of this I would like to get the normal black one and the paint the same bit's painted green on the nvidia one white. The case: Normal- http://www.newegg.com/Product/Product.aspx?Item=N82E16811345035 nvidia edition:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345052
thank you
A proper paint job wont hinder the airflow at all. Either get someone who can spray paint or learn on some old material. A rough job and it may look like a tin of jam has been thrown on it.
- can of primer, sandpaper, can of your colour of choice, can of clear + patience between steps/coats.
