8350 + noctua nh d14
As of now im at around 4.4ghz (210 bus 21 multiplier) 1.40v
Running 95prime for about 15mins and max core temp is 75c... is the oc too high? or does it not really matter cause ill never be maxing out the cpu in the real world?
Nope, you can go higher, easily.
alright so 25 mins and no core failures max temp 74.6C but the temp was hovering at about 72C
Could you give me like a target clock or a max temp that i should be doing on prime95?
(ASUS Sabertooth 990fx r2 mb)
