Okay first off I'm not being a jackass saying overclocking is easy. It's just that this is the first CPU I've been overclocking, that's all.
So I have an i5-4670k overclocked to 4.4 ghz on stock voltage, 1.25 volts. I know I can get more but since I only have the stock cooler right now I don't want my temps to get to high.
But I mean... that was so easy... I turned off the turbo boost & set the CPU multiplier & set the voltage... What else are you supposed to do? Or is it really that easy?
Are you supposed to overclock the bus speed, or does that not really improve performance?
Hovers right around 60 on a prime 95 stress test. I tested it for about a half hour straight with prime 95 running. Haven't had have any issues with it overclocked for about 3 weeks now.
Well, you certainly make it sound easy. If you didn't blue screen you didn't try hard enough! I thought Haswell was supposed to run hotter then hell?! 60 sounds kickass for any cpu.
well, more or less that's everything, i'm thinking you're just surprised that you got that that good of an overclock "that easy", sounds like one hell of a chip, get a custom loop on that bitch and go for a record
It's as easy as that. It can still be a pain to tweak voltages and other settings in the BIOS, but ever since netburst died it's so much easier. Actually ever since the first core i7 bloomfields, there's much less settings needed to be changed to get a stable high overclock.
You know the funniest part is you can even get lucky with a software OC, which is pretty much the same thing except automated. In 2 clicks, it's that easy.
OC software like gigabyte's or asus's are pretty safe, and thus most of the time you get a lower OC in auto. I've tried AISUITE for this i7, I get 3.95. which is 55mhz faster than the turbo clock and it just bumped the blck a bit.
In the BIOS I got 4.28 stable after messing around 4.35 and finding it too hot (bclk oc is hotter than changing a multiplier in a 4770k, but then again there's some unlucky 4770k cpus that don't oc much at all).
