Hi all I have some issues regarding moderate overclocking on a 3570k and wouldn't mind some input if anyone can help.
Firstly i just purchased the xigmatek dark knight night hawk edition to cool my 3560k which is in an asus p8z77-v-lk motherboard. I noticed a massive drop in temperatures on stock clocks at idle and under load through the difference between my coolest core #0 and my hottest core #2 is about 10 degrees no matter what the conditions i did some reading and some people said some cores will run hotter because single core programs will run on them etc i didn't really understand it but i am kind of dubious as i think whilst i seated it my opinion well the one core might not have been covered well (i used the pea method) I wouldn't mind some input regarding this.
Secondly having recieved my new cooler i propmtly overclocked it to 4.5ghz in the bios this is my first time overclocking as it is my first build. I used the offset mode for my voltage setting it to 0.055v after this was the lowest stable, which to my understanding is on top of what ever is typical. I ran prime 95 for like an hour no issues and was getting temps of around 60 and was content with this the voltage on the vcore in windows was reading 1.164 under load anyway i used it for a day or two before my computer started blue screening not even under load at first i didnt suspect voltage since i had had no issues so far but eventually i had to bump the offest up to 0.11 double to get it stable again. ADoes anyone no why this variation is needed and my vcore now reads 1.224 ia thia this too high in peoples opinions should i be able to go lower
thank you in advance i know there is probably stuff out there about this but everything i found seemed to be the similar but not applicable to my situation or past my depth of understanding
