Ok So here is my build
Case: Rosewill Challenger (3fans) 1led fan
PSU: Raidmax 530 watt
CPU: FX 4170
GPU: 7870
Im looking to oc my cpu and gpu I want to know I will have enough power from my psu is it safe to oc with only 530 watts? Thanks in advance!!!
your only using about 350 watts peek and overclocking won't change that much maybe youll use 370-380watts if you oc you cpu /gpu but a raidmax psu is'nt that good of a brand you should be looking at buying a good name psu thats 80+ "somthing". the short anwser is you have the over head to oc
