i used overdrive to do this i honesstly have no idea how to overclock
im using the hyper 212 evo and ive never overclocked before does this look good or do you think i can push it some more
You could prolly lower that voltage a bit, you might also be able to push it about 300mhz farther depending on your thermal paste application and your mobo.
if i use the default thermal paste would u seuggest bringing it up with my fan
depends on what temps you are getting.
39 celcius mostly
That's pretty high, you should prolly just focus on decreasing your voltage for now.
