Overclocking my XFX 6770
I have an XFX 6770, and I plan to upgrade in the near future, but until then, I want to do some overclocking. I just want to know, how hot is too hot? Also, does anyone have some speeds I should start at? The stock clocks are 850MHz core, and 1200MHz RAM. Thanks!
Really to be honest.
just play with it in your perfered software like msi after burner or evga percision x and see how that goes I would have to call anything over 80 degrees C pushing it but if you can get a good overclock under that then GG
Hope it helped!
