Hello ladies and gentlemens and whatnot!
Today i will start thread here about monitor overclocking Database! all results posted here (i hope) so everyone with same monitor can see their capability of panels, my panel can do 75hz info below!
not so mainstream to overclock monitors as other hardware so here i wish we will make this thing more...of a thing so to speak.
Idea here is that everyone writes their own Monitor model name example (I have Benq G2420HD) 2009 TN 60Hz monitor.
By usiing CRU ( Custom Resolution Utility) we will try to OC the Panels refresh rate from 60 to 65, 70, 75,80, and 83.
I have currently set 70hz so its quite safe, The difference is noticable!
Here is a link to the forum with a download link there ( Created by ToastyX) http://www.monitortests.com/forum/Thread-Custom-Resolution-Utility-CRU
also download pixel clock Patch for your choice of GPU
HERE IS MORE INSTRUCTIONS step by step with images: http://linustechtips.com/main/topic/31526-overclocking-your-monitor-refresh-rate-amd-gpus/
The instructions are there as well (Go figure)
1. Benq G2420HD 60 to 70HZ
75hz works too but i prefer 70hz as i feel more safe with it.
IMPORTANT!
(if something goes wrong, Boot into safemode and disable all presets so it goes back to native refresh rate so its can recover if you OC little bit over.) and im not responsible in case of fail,dont get greedy.
Tn panels can go upto 83hz and IPS to 70hz is max in my opinion in basic monitors.IMHO.
post your results here, Lets see what we get in 1 month!( i hope at least to see few results)
Happy overclocking!
