I have a p5k deluxe wi-fi ap and a Q6600 with ddr2-800 ram
MY current FSB is 387
Ratio is 1:1
If my FSB is 399, then my Dram Feq will be 800. Is that the highest I can go? Can it go any higher and still be stable?
Ratio is 1:1
nonono what brand is it? if its like idk crucial or corsair or any other higher up brand, itll go much higher, mine is sitting at 1066 and im using a 2:3 ratio. honestly i'd just keep going til A, temps on cpu get too high, B, it becomes unstable, or C, it doesnt boot.
Heres my ram (Regret buying it now)
http://microcenter.com/single_product_results.phtml?product_id=0286647
that ram should be able to go higher unless your sticks are bad. those crucial ballistix sticks are known for being able to be pushed.
if u must get something like this
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2552605&CatId=496
