I have an i5 4670k and an asus z87-a and i want to overclock it to 4.2ghz and im new to overclocking so i need some help. I just need to know the step by step and exact setting/instructions on how to do it. ( i have an aftermarket cooler and suggestions on voltages is greatly appreciated).
Thanks
i found a great site that has that information you need
http://bit.ly/11hl2M1
Hello! This is a great guide to overclocking Haswell CPUs! It is very through and there is lots of useful information: http://www.overclockers.com/3step-guide-to-overclock-intel-haswell
Just a note, Intel voids your warranty when you overclock. To be on the safe side you can get the Intel Performance Tuning Protection Plan which covers any damage caused by overclocking. It is only $25, so it is a great deal IMO. http://click.intel.com/tuningplan/
-fishymamba LTT IRS
There's no point in getting such plan. They're milking money. You can't buy a midrange part and overclock it to high end performance today, not even from AMD. Intel pre 2008 didn't have warranty voidable by OC. You're also not getting much from overclocking all the time, so check out the voltage options on your motherboard.
