Overclocking FX-8350 Ram question
I have one question, will this ram ADATA XPG V1.0 8GB DDR3 2X4GB AX3U1866W4G10-DR effect my overclocking? I have a FX-8350 and Asus Crosshair V Formula-z mobo. Target I am trying to achieve is 4.8ghz. I have the H100i, but wondering if I this ram will do, or should I opt for better?
It won't affect it at all. OCing is really down to the CPU, motherboard, and your cooling.
That RAM is very good anyway. Really, if you aren't using an APU RAM speed doesn't matter that much for gaming.
I have an 8350 OCed to 4.8Ghz and I have run a variety of RAM in it and it doesn't have any effect.
