Overclocking ASrock 990fx extreme 3
I would like to know how to overclock on this motherboard.
Here is my specs.
Video Card: ASUS DirectCU II Radeon HD 7790 HD7790-DC2OC-2GD5
Processor: AMD FX-8350 4.0GHz (4.2GHz Turbo) Socket AM3+ Eight-Core
Memory: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Hard drive: Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5"
(NO SSD)
Cooling: CORSAIR Hydro Series H55 CW-9060016-WW water cooler
Power supply: CORSAIR HX Series HX750 750W
Motherboard: ASRock 990FX Extreme3 ATX AMD with UEFI BIOS
Fans: COOLER MASTER R4-S2S-124k-GP 120mm
Operating system: Windows 8.1
Case: COOLER MASTER CM Storm Scout 2 Advanced SGC-2100-KWN3 Midnight Black Computer Case With Side Panel Window
I'll be very basic here just to get you started. You overclock most things by downloading ASRock overclocking utility or going into your bios and overclock from there. What you can't overclock from here is the GPU for that you can use ASUS own software (GPU Tweak) or something like MSI afterburner. You can monitor stuff easily with gpu-z and cpu-z.
Be sure to research what temperature your GPU and CPU can operate at to not damage your hardware before you go bananas on the overclocking.
NOT advisable 8core cpu with 4+1 powerphase i had a ascock  990FX  ex3 for a wile as a temporary motherboard it gets HOT at stock setings.
Oc the gpu leave the cpu alone antill you can get a good 6+2 8+2 powerphase motherboard.
