Overclocking an FX 6300?
This is mainly for people who have an FX 6300 overclocked but I will take suggestions. :)
If you have an FX 6300, what do you have it overclocked to? I'm going to be buying one for my build and I was curious to as what a safe and stable overclock since I've never done it before.
I'll be using-
Cooler Master Hyper 212 EVO
Gigabyte GA-990FXA-UD5 ATX AM3+
and Arctic Silver 5 thermal paste
As for my GPU- Asus DirectCU II HD 7950- what would be a good overclock?
Thanks!
I have an FX6350. It's a similar chip and it was really easy to overclock. I run it @ 4.7Ghz
I'll post the settings i have once I get on my main rig. (on my laptop now)
Ok, thanks!
I also have the FX6350. I run mine at 4.5 Ghz. It's not really for issues with the chip its just that I didn't want to be over 60C on the socket. Supposedly 70C is where things get potentially bad, so I could push another 10C but meh, 4.5 is still pretty good. I'm at about 1.38V at full load, but your voltages, etc. will probably differ as with any overclock.
I will probably bump it up to 4.5GHz as well. Seems like that is the most common overclock on this chip.
I have the FX6350.
I can push 4.4/4.5 @ stock voltages but anything 4.4-4.6Ghz i need +.025V
with +0.05V i can get 4.5-4.7Ghz.
I currently run it @ 4.7Ghz. My chip is able to run 4.8Ghz stable @ +.05 & .075V
Your settings will most likely be different because not every chip is the same.
amd chips should run cooler. It's what they're spec'd for. Don't keep pushing it if it goes above 55C. and make sure you watch your motherboard temps aswell. Don't push them past 45Cish
If you find a stable clock speed that you like try lowering the voltages. Lower voltage= better
To stress test use Aida64. and run an overnight burn. But watch it for the first 30mins as that'll give you a good indication of your thermals.
I'm not sure 100% one this but you may need to change your c1 and c6 power states to off. These can throttle your cpu frequency. personally. I didn't have to.
Use CPU-Z to see what voltages and clocks your chip is really running @ in real time. Task Manager can lie.
I'd say start off just working up to as high as you can get on stock voltage and see where your temps are. 4.5 may be common, but that doesn't mean you won't crash immediately when you start up. Then you can up the voltage and see how much higher you go.
Doing it that way you may find out that your chip works really well on stock voltage instead of just putting voltage really high and putting clock to 4.5 and working backwards with voltage. Could save you some time, and headaches. I have a different motherboard so I can't say exactly, but you might have issues with the vrms, etc. which would be rather undiagnosable if you just go straight to 4.5 instead of working your way there.
Also don't forget to adjust your LLC.(Load Line Calibration)
To be honest, some of that was like gibberish to me. :)
I think when I actually get my PC, I'll understand much better. I have never really tinkered with speeds and voltages since I've never owned a good enough PC to overclock. When I get my PC, I'll post pictures of my temps and voltages and see what you guys think.
Thanks for the help anyway, much appreciated!
i have my 6300 @ 4 ghz, purely because im using the stock cooler
That is all I will overclock mine to, I do not need something at 4.5GHz unless I get hard core with my gaming. I do like this processor a lot though. Perhaps not as much as the FX-8350 I have laying around but I am saving that for different build when I get more money.
