Hey guys thanks for having me and if there's a welcome thread I didn't see please let me know.
Specs
Specs
Look up a guide and you are going to want to look at the cpu multiplyer the cpu voltage and the base clock are the setting that will be changed.
Understand that, and I've looked at a few videos. Think the problem is I'm asking the wrong question.
How much GHZ do I need using GTX 670 to run 2013 DX 11 games like Crysis 3 at 60 FPS?
I dont think that your i7 will hold that 670 back very much I would try to get 4ghz out of it and more if you can get a higher stable oc then that. If you want more fps make sure you overclock your 670. You could even get a after market cooler like the accelero mono and bios mod your card to get a big overclock out of it.
Yep that's what I was thinking, after studying a few youtube videos I've learn how the x58 bios work. 3.964 GHZ, 1568 MHZ RAM, and 1.3v is what I'm at stable for some reason it's not listed in my control panel under system, but shows results on E-LEET with 84 celsus at max load. 4.2k was also tested, but with 90+ temps on mad load which I wasn't to comfortable with. Before I purchase a new motherboard, and chip I'm going to water cool or NH U12 S the processer for 4.3k+ results under 85 celsus temps even if it only last another year of temp abuse.
