Overclocking 7870?
Is overclocking the 7870 worth it for gaming. I'm not going to be changing any voltages but probably just using the AMD overdrive feature if I choose to overclock.
Say if I overclcok the 7870 (stock clocked at 1030Mhz) to 1100Mhz would it really be making much of a difference? Is it worth it to loose your warranty for 70Mhz? Also is overclocking the memory speed more risky? And finally if someone overclocks and gets a blackscreen does that mean it caused any damage or was it like a saftey feature to cut off any damage which may have been done?
In case you're wandering the specific model of the GPU is Powercolor HD7870 Ghz Edition
This probably isn't important because I'm not changing voltage but my PSU is a Corsair VS450 and my Mobo is Asus M5A78l-M/USB3
TLDR; Is loosing warranty for a 70Mhz increase worth it? Would it actually improve performance?
Thanks in advance.
i'm fairly certain that it is impossible for them to tell wether the card has been overclocked or not, so your warrenty should be safe
also, yes overclocking a gpu can give quite sizable performance increases, but 70 mhz is pittiful, a 7870 is one of the best oc-ing cards on the market, you don't have a great cooler, but personally i run into stability issues before i run into thermal issues and that's at 1250mhz
i've never heard of oc-ing the memory being more risky
if you get a black screen, or more commonly either a blue screen or a artifacted blue screen, it will be because it either got too hot (a time after the oc) or because it just wasn't stable (right after oc/ as soon as stressed), if it got too hot it was likely a safty feature but you still could've damaged something, if it just wasn't stable no harm done
Thanks for the response. I take it this card is not made for OC'ing as it starts to get unstable around 1150Mhz core and 1300 memory clock and tends to give black screens. I think I'll stay safe on this one, I might change my mind later on when it becomes dated and the warranty expires.
As long as dont flash the bios its impossible to tell if the card has been overclocked.
+70 would make the card perform maybe 5% better, with changing the voltage you could get around 20% better performance (the limits in Afterburner etc. are safe btw., if anything is still wrong after a restart the card was defective from the start)
