does anybody know how, or can you find a guide on how to OC this cpu?
Here: http://www.tomshardware.com/reviews/fx-8350-vishera-review,3328-2.html . Not really a guide, but they show you all the voltages they used for their oc. There others, but I can't find them right now. Probably just search "amd piledriver review oc" on google are something.
Cheers,
Z
Interesting. I´d like to know whether undervolting a CPU is bad for it. In other words, will it get damaged even if it runs stable afterwards?
no, the opposite, it last longer
Cool, thank you gigabuster. Time to get into this then. From what I know AMD tends to set the base voltages pretty high so there´s room for undervolting.
im trying some of these and they seem to work, i think my phenom II x4 965 was a bad chip
