Overclock Temps
So I Have my FX-6100 overclocked to 4.5ghz at 1.385volts and Im getting 2 completely different temps on the 2 programs I am using. HWMonitor is saying that im at 71C at max load and CorsairLink is saying im at 56C at max load..... If anyone could tell me which one to trust that would be great.
Im not sure which one i'd trust, but I use speedfan and it works great for both temps and controlling your cpu and gpu fan speeds, too. I tested the program with a heat sensor gun, and it was within two degrees celsius accurate from the program. You should give it a try.
Alrighty will do. Thanks
