It means you send a signal beyond what is listed in the range for the monitor. For instance most 60hz monitors will overclock close to 75hz. You’re just making a custom display resolution where you specify that. In most cases they dont skip frames, youll just go outside their working range and the input will be dropped. A lot of displays dont overclock very far these days, its not like you’re going to go from 60hz to 100hz unless the driver board was already designed for that kind of refresh and wasnt reporting due to firmware or something.
used to overclock vga monitors using nvidia driver stuff back in the day, as in actually force a higher than spec refresh interval, but idk if it’s practical on digital connections or LCDs
I mean the difference between 60 and ninety is a lot more noticeable than 90 and 120 or 120 and 144 for sure. I don’t think it conveys a meaningful benefit unless you’re starting at a standard refresh rate to begin with.
So on the left (in blue) are FPS, on the right (in orange) is Frametime.
As a table:
FPS
Frametime
24
41,6
30
33,3
60
16,6
75
13,3
90
11,1
100
10,0
120
8,3
144
6,9
As you can see, while the FPS raise fairly linearly, one could choose nicer numbers and get it truely linear, to topic.
While %-improvements are the same, the Δ-improvements get smaller and smaller.
As humans tend to work logarithmically, the smaller the improvements, you will less likely notice them squared.
Not always, some will happily display the image but put a big fat ‘out of range’ sign over the output. Others may just skip frames and keep outputting at whatever the default rate is.
The latter would happen with my old Cintiq 12WX at 75hz. It was handy at the time at least, because it kept games from having frameskip issues that can occur when running multiple monitors at different rates.
Yeah, that’s what confused me. On Newegg their ads show the F model as the G model. So whoever is creating that particular ad is seriously shitting the bed. There’s no FUCKING OVERCLOCKING for ANY of those monitors. It just runs AS-IS out of the box at 144Hz. And for that much money, it fucking better…
