My build: Gigabyte 990fx-UD3 Mobo
Amd Fx8350 CPU
Cooler Master 212 Evo
What is a safe ocerclock i could use for the 8350?
Amd Fx8350 CPU
I had a stable 4.6ghz with an 8350 on a 212 evo. I don't remember the voltage, but the chips tend to vary a bit anyway.
Short answer, I wouldn't. That board doesn't have very good power delivery, and the cooler doesn't have too much overhead for overclocking. You're welcome to try but good luck getting your system stable,
You should be able to get a decent overclock 4.5-4.6Ghz. That Mobo is a little on the budget end but it should be fine. I have an Asus Formula and the same processor with an H100i on it and am only getting a 4.8Ghz 24/7 stable. So, its more or less how lucky your FX 8350 is. Just keep your temps below 60c during stress tests and see what you can pull, I kinda doubt an 212 can handle high voltages on this CPU so be a little careful.
Are you srs? 8+2 power phase I got the 990XA-UD3 and it works,and the FXA is better.
get a better cooler, a 212 just wont do it for a decent overclock. The motherboard is lacking a bit on the power delivery as well.
I have the FX6350 which is the same chip just without two cores- Here are the overclocks I'm able to get
REMEMBER that overclocking your parts will make then run hotter and reduce their lifespan.
Work your way up from 4.4Ghz each time doing a 15-20minutes stress test on aida64. IF it;s successful move up until your too a point where you're comfortable.
if it crashes try a higher voltage.
Make sure you watch your temperatures. I personally would not let it get above 65C. I have a xigmatek longass name cooler II with fans in push/pull and Mine is able to stay below 55C on a stress test (45ish in games) (21ambient)
motherboard VRM temperatures: Do not let these exceed about 48/50C. On this motherboard the VRM is not properly cooler and is partly exposed.
