I have a kit of: G.SKILL Flare X5 series AMD EXPO 32GB (2 x 16GB) 288-Pin PC RAM DDR5 5600 (PC5 44800) Desktop Memory . I wonder how I might go about over clocking it up towards 6000. HD info says its Samsung memory
What’s it’s rated voltage?
a good start is undo your XMP to auto than setting the Ram Voltage to 1.35V safe and reboot into bios, then set your ram Clock to 6000mhz and reboot and let your mainboard train it on its own. (it will reboot a lot so dont worry, let it do its thing) worst case you are greeted with an overclocked failed message.
6000mhz is not that much of a hustle.
From there you can watch some Youtube Videos on how to optimize your timings and how to test stabilitybut that is an IMHO an Milklady calculation at that point.
1.20 Volts
