Just wondering if there is any way to lower the output impedance of the Xonar stx.
It's not something you can really change. The Texas Instruments Op-Amp it uses has a stability issue without at least a 10 Ohm impedance across the output according to the spec sheet. There IS one amp that has managed to use that chip while keeping the output impedance low, but it's a very expensive trick. You can, of course, bypass the headphone amp entirely and use another one with the Xonar's line out instead, but that sort of defeats the purpose.
Do the opamps determine the output impedance?
