My old build finally crapped out so I’m building a new workstation. I ordered a couple Samsung 970 EVO M.2 drives on Amazon and got a fraudulent product.
I’m not sure if I should trust the other drive or how to check the other components (i.e. mobo, etc) for tampering. Seems very sketchy.
this is why I prefer buying in store, but amazon screw ups like this are pretty comical, sorry to hear about your hardware but hopefully they will send legit parts this time
This is can be kinda common especially on desirable products.
My first 9700K was actually a Core 2 Duo.
Amazon isn’t great at checking returns. So people buy things, replace the product with something else and return for a refund. I wouldn’t worry about the other drive or other components. They don’t all come from the same place or likely where in any way related. Just luck of the draw really.
I’ve had this happen with instore purchases too homie
The number of software boxes that got returned to the store I worked at back in the day, shrink wrapped, with an AOL trial CD inside instead…was pretty astonishing.
More recently I picked up a smoke detector from one of the big stores and it had somebody’s 20 year old detector in the box instead.
I know quite a few people who did it with the Xbox 360 when it first came out. So many of them had problems. So you’d buy one at Walmart, take it home, swap the HDD, throw your red-ringing one back in the box and return it.
Or the CD would be copied and they would “forget” to return the code wheel or other forms of copy protection.
