Hello people of TekSyndicate. Com
How would I orient all 6 fans (noctua NF-A14) in a define R4 for maximum cooling capability?
Put two on them in the front as intake and put one on the bottom as intake.
Put two on the top as exhaust and one on the back as exhaust.
I actually have all of my fans (as many as possible) as intakes aside from the top fans which are output. I think that this helps to keep the air flowing the way that it wants to (heat rises). I have nothing to back that up, and just about any halfway reasonable configuration will do just fine since you have a ton of fans.
This is almost always how I arrange my fans with one exception.
If my case has a fan on the side panel (Where the window is in most cases) I orient that as an exhaust and the rest as intakes, if its a large fan, or the side panel and top as exhaust. I also turn my cpu fan over so it's blowing upwards. Why people have a fan firing downward and pushing the heat from their CPU heatsink across their mobo, RAM, and voltage regulators is fucking beyond me.
