What are some good cases for water-cooled systems?
I am contemplating doing a new PC build in the coming months, and I am adamant that this one will be water-cooled, full ATX. I will only be cooling 1 GPU and the CPU, and thinking of getting a 3 or 4 fan radiator in the loop (loading it with Noctuas, and then resisiting/slowing them), unless suggested to do otherwise. I currently have the "Cooler Master Cosmos S", I assume it may be all right for water-cooling, but thinking of changing it for something a little smaller - haven't decided.
I should add that I am wanting to add a radiator (possibly another 3x fan radiator) between the CPU and GPU, in addition to the other 4x/3x fan radiator. More fans, slower speed, cooler, quieter (or that's the intention).
All suggestions welcome. But if you state/list any cases, please qualify why (number of radiator space, what experience etc.). I look forward to some interesting suggestions.
P.s. Apologies if this is a repeat post...I can't find a search function anywhere :-/
What is your budget? Aesthetic/material preference?
Anything up to £300 (~$489.60), though would prefer cheaper, of course. I (currently) have no aesthetic/material preference - I'm open to ideas.
I am really interested in just exploring various recommendations...my only real criteria is that it can comfortably house a water-cooling loop.
I think your best option for ATX with mutliple 120.3s is the Caes Labs M8; supports up to 4x 120.3s (one slim, two really think, one decently thick) without the pedestals, which can hold another 2x 120.3 thick rads each. Incredible quality, customizaton options, and overall out-of-box features. Amazing case, amazing guy, and right in your budget.
If you don't want a double-wide, get a Case Labs SMH10, which is a single-wide, with loads of WC support. Up to 2x 120.4s (maybe 140.4s), and a 120.3, if I'm not mistaken. Same quality, options, and such, like with all Case Labs.
Another case that you can look at that isn't as pricey is the Cooler Master HAF Stacker 935. It comes with a removable compartment that can house 2 3x120mm fan radiators. As far as needing to put a radiator between the CPU and the GPU, that isn't necessary. The coolant will only increase about a degree or two from one component to the next and after the pump has been running for a couple of minutes the temperature equalizes anyway.
It's a common misconception that the heat from one component is transferred to the other in a water cooling loop. This isn't the case. Due to the speed of moving coolant and the ability of the radiator to dissipate the heat, the heat transfer to the coolant from one component to the next is usually less than 2 degrees. So long as you have an adequate pump there is no way for the coolant to heat up any more than that because it's cooled by the radiator too quickly.
Thanks for the clarification! Will certainly make my loop design a lot easier now.
The HAF Stacker sounds intriguing. Looks as though I could put a separately running NAS/media/other server in one of the modules. Could be fun to play with.
