on newegg they say that in order to use an optical drive it must come with a software is that true ?? cos i bought my lite on optical drive it came alone with no software. help !
Yes and no. Usualy most devises can do the standard "reading" without any extra drivers. It is usually that you need extra drivers for Burning, och perhaps High speed reading and DVD/Bluray video playback
can you download them ?
look at the website for the manufacturer of your optical drive
windows generally installs all the neccesary drivers on its own when you first put it in
ok thanks guys
