This is what I would like to do, do I need an active Splitter? Any recommendations? I’m lazy and I do t want to walk to my razer soundbar to adjust the volume every time.
Uhm the Soundbar is outputting the sound that is coming from the PC and the TV right?
Then this is not a splitter, it is a switch.
And yes they do exist and yes they do need power, usually a 12V adapter or just USB these days.
Something like this
https://www.delock.de/produkte/S_18767/merkmale.html?setLanguage=en
You don’t “need” a powered switch. I use a dumb splitter as I am using short runs all at the TV.
Something like this will work, but if you have long runs, stick with a powered solution.
https://www.monoprice.com/product?p_id=966
It is all analog [read just routing light] so no power is needed but it will cut the light intensity in half-ish so not good for long runs.
Haven’t seen these kinds of splitters before, but yeah I guess they are only usable for short runs since the light intensity is not all that high to begin with
