The board supports optane clearly. And if through my mental illness I’ve installed into the incorrect slot I have tried both M.2_1 and M.2_2.
W10 recognizes the drive fine. The optane software Intel Optane and Storage Management does not. Have not seen anything in the BIOS to “turn it off/on.” Not sure if it should but the BIOS recognizes the drive but not the fact that it is optane
I have tried the recommendations online to fire open cmd as admin and clean drive via DISKPART. No dice.
What may be worth noting is, using RST, I have a RAID 5 setup. It would be silly to me that only one of the features of the software could be used.
Found the setting in bios, RST recognizes the device in BIOS but Intel Optane and Storage Management (or “IOSM”) does not as an optane device though recognizes drive.
As it didn’t appear immediately in IOSM I installed the iaStorVD.inf from the below. Got a message that the install was successful. Rebooted. No luck.
Look, first you need to make a decion - do you want use optane drive directly as block strorage device or do you want it be invisible cashing device for your existing storage drives? You CANNOT do both.
Generally speaking both intel and amd swraid is not good idea, on intel is worth enabling only for optane caching if desired.
In the second screenshot, option (SATA Mode) is where you make that decision. RAID/Optane mode == intel software raid == RST.
For option A) you have to disable RST in bios and choose plain old AHCI. Then you will be able to see and work with the drive as normal ssd device. Use it as system partion or scratch drive, up to you.
If you want to use the way “intel intended” as a cache device using RST, then you are already set. You will not be able to directly access the device, everything is done in background by RST software.
There is also third option. managing the raid on OS level - storage spaces configuration on windows systems and mdadm or btrfs on linux. This is advanced and potentially fragile teritory, so go there only if deeply interested in IT, willing to self support and willing to invest a lot of time beforehand.
I did flip these settings to optane mode, optane gene, and the pcie remap and had no success. Is it that one could only do this if starting an array from scratch? If thats the case then I will have to consider alts.
Intels storage and mem management software still recognizes it as a pci device and not an optane supported device
Going to abandon/request closure for this post. Not due to lack of advice, everyone was very helpful and I appreciate the advice. I was never able to get this working and its turned into a time sap. Will put aside the drive for a future date.
