So I was able to successfully move my opt directory to another drive.
I first tried just doing a direct link in fstab . . . yea that ain’t gonna work.
So I just did a symlink ln -s opt and that seemed to work.
I’m doing this because apparently CUDA and Davinci love to use the root opt and it just ate up space. Yes, I only gave my root directory 70 gb of space. I kind of thought I wouldn’t need anymore. . .
Anyways weird issue I know but if you’re wondering if it’s possible, yes you can do it.
Also for davinci, you need to have ownership of the davinci opt folder as your user so it can write your serial code down which is stupid and dumb.
