Hey Logan, what do you think of this build? is it any good?
CPU: AMD FX-8350 4.00 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology, (Extreme Overclocked 20%)
Cooling Fan: CyberPow erPC Xtreme Hydro II Liquid Cooling Kit 360MM w / XSPC RayStorm CPU Block,Dual D5 Pump & Reservoir, AX360 Radiator w / Triple Fan(CPU & GPU Liquid Cooling,Ultimate Overclocking Performance+Extreme Silence at 18dBA)(All Venom OC Certified)
Additional Liquid Reservoir: EK-Multioption EK-RES X3 400 Reservoir
Motherboard: [CrossFireX/SLI] ASUS Sabertooth AMD 990FX R2.0 Socket AM3+ ATX Mainboard w / UEFI Bios, TUF
Thermal Radar & Components, 7.1 HD Audio, GbLAN, 4 Gen2 PCIe X16, 1 PCIe X1 & 1 PCI
Memory: 16GB (4GBx4) DDR3/2133MHz Dual Channel Memory Corsair Vengeance
Video Card: 2x NVIDIA GeForce GTX 690 4GB 16X PCIe 3.0 Dual GPU Video Card
Power Supply: 1,500 Watts - Cooler Master Silent Pro M2 80 Plus Silver Certified Modular Power Supply
Hard Drive: 512 GB OCZ Vertex 4 SATA-III 6.0Gb/s - 535 MB/s Read & 475 MB/s Write (512GB x 4 (2048GB) Raid 0 Extreme Performance
Data Hard Drive: 512 GB OCZ Vertex 4 SATA-III 6.0Gb/s - 535 MB/s Read & 475 MB/s Write (512GB x 4 (2048GB) Raid 0 Extreme Performance
Hard Drive Cooling Fan: Vigor iSURF II Hard Disk Drive Cooling System
Optical Drive: LG 14X Internal Blu-ray Burner, BD-RE, DVD+RW, 3D Playback Combo Drive
Sound: ASUS Xonar Essence ST 24-bit 192KHz PCI Sound Card
LCD Monitor: 32" Widescreen 1920x1080 Sceptre E320BV-FHDD LED 3DTV w / Built-in Speakers, VGA & HDMI-Input
2nd Monitor: 32" Widescreen 1920x1080 Sceptre E320BV-FHDD LED 3DTV w / Built-in Speakers, VGA & HDMI-Input
3rd Monitor: 32" Widescreen 1920x1080 Sceptre E320BV-FHDD LED 3DTV w / Built-in Speakers, VGA & HDMI-Input
Network: Intel Pro Gigabit 10/100/1000 Network Card
Extra Thermal Display: NZXT Sentry LX Aluminum High Performance Fan Control, Clock, & Temperature Display
Wireless 802.11B/G Network Card: Linksys WMP600NWireless-N Dual-Band Adapter
Power Protection: OPTI-UPS TS2250B 2000VA/1200W Uninterruptible Power Supply
If you can, talk about it in the show, thanks :)
