Opinions on ITX build to be
I have put together a small Frag-Box and I want some input on what could be better or improved for the same price of $1000. Thank you very much for any help and support!
http://pcpartpicker.com/p/17nm3
Look into getting a AMD card, if you don't need the geforce experience, and maybe an ivy bridge cpu. It might keep temps down and might find it for a little cheap. Otherwise, Looks great!
Do you think that the power supply will be fine running this config?
It's perfect. You can try for a 400w and that would work just as good. Go for it.
I am wondering if I could get away with putting in a 7950 in this machine instead of the 660 2gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150588
Also the PSU I will be using has 37 Amps on the 12v Rail. AMD suggests using a 500w powersupply with 25A.
I would recommend that you get a 7870ghz and use the money you would have spent on the 7950 for games. A 450 should work on the card, but it will not give you any room for overclock. Furthermore, do you plan to overclock?
No I do not plan to overclock. Saving $20 on a non-K CPU
You should be fine with that then.
wow that psu is on a rediculous price... you can get a much better  psu with 550W 80+ gold for less, gives you more room.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151119
Seasonic G-series 550W 80+gold. its semi modular, so not fully modular, but who cares cause you do need the casual cables....
grtz Angel ☺
