Hey guys I plan on building a pc soon and I wanted to know what you guys think, should I replace things? I'm mainly going to be gaming on it so here we go.
I would say ASRock is a good brand of motherboards, reliable, and easy to overlock with. Their Xtreme Tuner OC program is easy to use so you will have no trouble overclocking your system if you get a good CPU Cooler. One of my friends has this in his build and he hasn't had any hiccups nor problems with it, though he doesn't overclock at all. If you don't want to go with ASRock, I would reccomend Asus and Gigabyte, they are reliable and my previous build had an LGA 1156 Gigabyte mobo in it. That build lasted me 3 years or so without issues.
Well, I do know that Seasonic has a 650w 80+ Gold Certified PSU that is fanless, so it has no noise. If I had the money was building something like your build, that would be my top choice. 650w is more than enough and even gives you some head room for extra Hard Drives, SSDs, a Wired/Wireless network card, and even a sound card. Not saying you should try and throw all of those things at a 650w PSU, but you could definitely do minor upgrades with some headroom and confidence. I have had my Seasonic PSU for close to 5 months now, and it runs at a steady rate and not even much sound.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087&Tpk=seasonic%20x750&IsVirtualParent=1 I actually own the one I just linked. They are similar, the one I has just has 750watts. I personally love Seasonic for their PSUs, reliable, quiet, and they have the understated look I was going for in my build with the little to no logos on the outside. I would have gone with the fanless 650w PSU if it weren't for me wanting to try out SLI with my GTX 580s, which 750w could NOT handle at all. 650watts should be more than enough if you don't want to do SLI in the future, and if I were getting a PSU to carry on to future builds, a fanless one would be my choice because it is bad ass, quiet, and modular so you can make the best of any case even if it doesn't have good cable management.
