Opinion on parts
Is this a good build?
http://pcpartpicker.com/user/SirArthur_/saved/1sQ5
Total budget?
700
http://pcpartpicker.com/user/armypig/saved/1sQk
Is the sapphire 7870 better than the xfx?
yes, xfx sometimes has really bad cooling issues, and sapphire has great support unlike xfx imo
its worth $15 more, but if you can afford it, get a sapphire 7870xt
http://pcpartpicker.com/user/toast/saved/1sQH
And if you really need a wireless adapted just get a cheap USB one.
The (xt) vershon is a bosted 7870 that gets very close to a 7950 its a very good card for the extra $$
Thank you guys! :D
