A lot has changed in the past year in the world of Linux. Since the the last release of Opensuse (13.1) the landscape has progressed quite a bit. Has Suse's latest entry changed with the time or will it be passed up? I run Opensuse on my MSI GS 60 ghost to find out.
Installation:
Opensuse has it's own installer that differs from Fedora's Anaconda installer and Ubuntu's installer. The partitioning manager does a nice job for an automated pationing scheme. I only had to make a slight adjustment.
The installer gives you the option to turn ssh on or off before the system has been written to disk which is handy if you want to run it headless.
Opensuse is fully compatible with UEFI and secure boot which is great if you have a Windows 8 laptop. BTRFS is now the default file system for OpenSuse and it rocks (more on that later). A really neat feature is it will show you a system map of your partitions for us visual people.
The Software:
I used Gnome for this install so I can't speak on KDE expect it is not running KDE 5.0 since it is not considered mature enough.
13.2 comes with the usual suspects of software like Libre Office, Gedit and Firefox. Gnome runs Shotwell instead of the Gnome image app which I find to better since it has more options.
But, where Opensuse Really shines is with Yast. Think of YaST as the Windows control panel on steroids. You can get into the nitty gritty of the OS without having to touch the command line. I love the Snapper tool which allows you revert to previous BTRFS snapshots if you screw up your system. I had to use it when I locked myself out of systemd (don't ask) and it is a life saver.
Under the hood Opensuse is running Linux kernel 3.16 which isn't as new as it could be. But installing kernel 3.17 isn't too bad and really needed if you plan on installing it onto a Surface pro or other x86 tablet.
Apparmor and systemd installed by default wich add a nice layer of hardening to a stock install. Systemd sandboxes your daemons (services) and Apparmor limits the reach of programs so, to prevent malicious code from doing too much damage. The firewall settings in YaST are adequate for most users.
Use:
I have made Opensuse my daily driver on my MSI GS 60 Ghost, and it shows that this system has no problems with new hardware. Installing software is a breeze with one-click installs on the Opensuse website and more distros need to adopt it. Zypper, the command line package manager is just as easy as apt (Debian's package manager). But you don't have to use the command line because Yast has a software tool that is very intuitive.
On a negative side there is a fair bit of programs (like steam) that isn't in the official repositories (software sources) and must be added through the build service. It isn't a big deal because it can be done as a one-click install but it does irk me.
I did have a a dependency issues with Chrome (gotta have netflix), lsb wasn't installed but could be added through Yast easily.
Getting Nvidia hybrid graphics (Optimus) to run was a massive pain but that is an issue across Linux because Nvidia doesn't seem to make things easy for us penguin users. Linus Torvalds has a few choice words for Nvidia when it comes to Optimus.
Systemd does take some time to get used to if you have been using Linux for a while, but that is what the man pages are for.
If Novell and community take forever for the next release you can place the OS in a rolling release cycle (Tumbleweed/Factory) by changing your repositories.
Conclusion:
Opensuse 13.2 is a cutting edge and easy to use distro with some great power user features that don't require use of the command line. Totally recommend for both those who are new to Linux and the saltiest open source users among us.
Give it a try today: http://software.opensuse.org/developer/
