This will span into 2022 due to the amount of time it will take to save for parts.
Decided to do a EKWB SE 280, XSPC Slim 240 and XSPC Slim 120 with 140mm top exhausts and all Corsair ML fans. (and potential small VRM fan)
I’m gonna go with Alphacool soft tubing, Koolance QDCs, EKWB fittings and a Aquacomputer D5 Res combo.
9900K will come when I can buy one retail. Radeon VII is from my friend sometime in 2022, and the rest will be when I can buy them via Newegg and etc.
Since this might take an entire year until next year, I locked myself into these parts because it’s the end of the line for OSX Catalina compatibility (Not gonna install Big Sur) The Prime Z390-A was tested working for Mojave and up, hence the ATX case in the Mini.
I didn’t actually know the mini was ATX, I think I’m still gonna go with a regular dynamic for my build though, even low wattage SFX is just too expensive
turns out 2 650w seasonics, a PSU sync cable, and a O11 Dynamic is cheaper than a single 1200W PSU
Okay, reconsidering that this is gonna be a major part of my Valve Index experience, I’ve asked about whether the Radeon VII is a wise investment, and I’ve come to the conclusion that it should be left alone in terms of sharing the loop with the CPU. The Radeon VII I’m getting already has a 120mm AIO installed, and my 6900 XT upgrade in late 2022 will use the TUF Gaming 6900 XT with a EK Waterblock.
Now that I have a clearer idea of upgrading to the 6900 XT, should I buy the waterblock for it ahead of time or wait till late 2022?
