One SSD for Boot drive and second SSD for cache
I'm looking for a z87 moterboard that will allow me to create such a SSD setup with one SSD for boot and other one for cache. Will I be able to do this with Asus VI Formula?
For the caching use Intels SRT tech, place both the drives in the ports specified in the boards manual (the Intel controller). Go through the caching wizard. Done.
Place the other drive in another controller.
So I would have to use the non intel controled sata ports on my mobo for boot drive?
You'll have to have a read of the manual buddy to be sure, it's available on the motherboards webpage. It shouldn't matter because you have to manually select which drives run together anyway in the SRT wizard. There is a good video made by Linus detailing SRT on YouTube.
allmost every decent Z87 board should be support SSd caching.
I know that, but I'm curious about the described configuration, because from what I recal only one asus z77 MB suported ssd boot drive and a second ssd for cache from first two sata ports.
well then you have to look in the manual indeed. but i not realy understand what your goal is.. you want to use a SSD as a boot drive, and a second SSD to  cache a storage HDD? you probably need to connect the SSD and HDD to the intel controler, but im not sure.
Yes I want to cache a HDD with a second SSD for photo editing. I know what I have to "probably" do, I was thinking someone here did something like this and will know something for sure, not just presume. Anyway thanks for Your reply.
The caching thing is really cumbersome. More headaches than worth but if you have two unlike ssds/hdd than its easier than getting two drives in raid 0.
The caching is limited to caching 64GB. Do the math if its a 120 gb or 124 for instance you will have ~60 gb to logic partition after caching
There is also a bios setting to switch the controller setting from AHCI to raid.
I've actually done this and booted on an OCZ agility 4 256 gb with a 64 gb kinsgton caching a 2 TB cav black. Again it becomes more cumbersome.
What I've done now for video editing is using two SSDs. One for boot and editing software and the other for editing. Both are 256 GB.
As far as caching on the z87 look for this in the specs Supports Intel Smart Response Technology. Thats the program for caching. That also has a setting in the bios to change that too. Course look in the board manual or the pdf online.
Its all there in the manual mate, otherwise there is the SSD/HDD hybrid drives or RAID 0 (2xhdd's).
I've read Formula VI manual and it's not there, but I've got the answear from JJ.
For SSD Caching your boot drive technically is the HD not the SSD and you attached the SSD after the OS is installed. You can then attached any other drives you want to run in a single drive operating mode. While technically possible it will not be able to be done via the RAID manager that is part of the Intel option rom. Additionally i generally only recommend RAID1 for pure data drives as if you have a virus,malware or some type of infection or any OS related issue it is still on that duplicated drive. RAID is best when you want a backup and redundancy to your data.
If you have two SSDs though ( one large for your primary OS? and another specifically for improving the performance of your mechanical HD you will want to
1. Install the large primary SSD ( with RAID mode enabled for SSD caching support )
2. Once the OS is installed on the primary large SSD attached your SSD for SSD Caching and attach your mechanical HD and complete the SSD caching setup ( SRT )
That exactly what any SRT tutorial states.
