Also i indeed saw that post, and tried the command with the right amount of sectors.
The command ran fine but it did not solve the problem.
Had to destroy da0 again after that.
These are brand new usb’s.
But what’s the point of running redundant boot drives if i can’t replace one when it goes down?
It’s just like saying my headlight is not working how do i replace the bulb?
just buy a new headlight it already has a bulb in it.
I’d like to fix the core of the problem.
Your solution is indeed a solution, but it’s a last resort solution.
I really don’t have much time to f around with these things anymore it just needs to work.
I do really hope you have the knowledge to help me fix the core of this problem.
