Ok, so i want to replace my motherboard in my dell system, will there be a problem switching all the hardware onto this motherboard, ASUS P8P67-M PRO-R LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard ?
You'll have to be more specific about what you currently have in your system. Some components might now be compatible. Some please correct me if i'm wrong, but I don't think dell uses standard atx motherboards so the case might not be compatible.
Got a main gtx 770 i5 3340 generic memory 8gb
Seems everything would fit component wise, can anyone else confirm this please?
Ok so here's an update I want the new fx 8350 so will an amd motherboard work with the components without installing a new os?
