One Box To Rule Them All (maybe?)
AI Disclosure:
I’ll make sure to update this as I go, but I do use AI to help flesh out some ideas, perform research, and write some of the scripts that I could probably find on this forum. Should anything be developed via AI, rather than AI as a tool to help, I’ll be sure to make that very clear.
My idea for this is very simple. Can you build a server out of one computer, for not a bunch of money, that can do everything.
Router? yup. Switch? yup. Game server? yup. File server?? yup. email? yup. Workstation VM? of course! home security? duh. gaming vm??? sure why not! I think you get the idea…
The goal would be that you either have a Chromebook (cheap), or hook this box directly into your bedroom or living room TV.
While I’m sure this isn’t a new idea, my goal here is how much use can you get out of some old hardware and a bit of cash. Oh and I want the whole thing to be scripted… yes all of it, with a “hello user, what do you want for this?” for the things I can’t possibly guess at.
I’ll come back and edit this into something nicer after I’ve fully decided on what I think should be required for such a system. I’ll also include, as best I can, the cost of each and every component so people can figure out based on this project how much more or less they need to spend.
I’m hoping to learn a LOT more about virtualization and how to better handle resources in a constrained environment, both in a compute sense and money sense. It always seems like “all in one” either means lots of money, or compromises.
I’ll also likely find a friend/family to give the system to and see if their non techy self can live with it for any amount of time.
Sure you can do all this. But it’s a lot of eggs in one basket, and making very little do everything, tends not to work out well.
There is a reason VM host servers have lots of CPU cores, memory, and storage.
I’d hope most people on the forum know this is a horrible idea, but it’s probably a good point to call that out, as my wording seems a bit too hopeful in the post lol.
It’s less of a “is this a good idea or should you do this?” And more so of a “if you had to what does it look like?”
Also aware that a certain baseline of resources is needed to even attempt something like this.
Just a dumb idea I always had every time the forbidden router is mentioned, and Devember seemed like the right time. Open to alternatives in the same vein that could benefit others though.
You can put everything in one box. Just be aware of creating single point of failure and dependency entanglement. Probably you need to put the router in a separated box so that you don’t lose the internet while rebooting your server.
BTW, the first option should be Docker, not the VM.
This depends on what “bunch of money” is to you. You defined what what you want to do exactly with very high requirements, but then when it comes to the money part, it’s “bunch”.
Putting my own number on “bunch”, no I can no do what you want.
I do run most of my home services off of one 24/7 “server”, but it did cost a “bunch” to do it right.
You should look into Wendell’s “forbidden router” video series. The idea is basically what you seek: you build 1 box running a hypervisor (proxmox, xcp-ng, what have you) that runs everything. The “forbidden” part for the router is that it’s running as a virtual machine with a network card passed to it.
